Parrot FLYPAD Buttons Replacement
  1. Parrot FLYPAD Buttons Replacement, Buttons: step 1, image 1 of 2 Parrot FLYPAD Buttons Replacement, Buttons: step 1, image 2 of 2
    • Position the controller so the back is facing up.
    • Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Buttons Replacement: step 2, image 1 of 2 Parrot FLYPAD Buttons Replacement: step 2, image 2 of 2
    • Remove the foam adhesive that connects the front plate to the motherboard
    • The buttons (L1,R1) may fall out. Set aside to replace during reassembly.
    • Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
    • Remove the motherboard from the front plate.
  3. Parrot FLYPAD Buttons Replacement: step 3, image 1 of 3 Parrot FLYPAD Buttons Replacement: step 3, image 2 of 3 Parrot FLYPAD Buttons Replacement: step 3, image 3 of 3
    • Remove the buttons from the front plate of the fly pad and replace as needed.
    • Hold the front plate of the fly pad facing downwards to prevent buttons from falling out.
    • Make sure the text on buttons L1 and R1 correctly line up with L2 and R2 when reassembling the device.
2 other people completed this guide.
HUY NGUYEN
376 Reputation
3 Guides authored
UW Tacoma, Team S3-G5, Liner Spring 2017 Member of UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 647
