Parrot Skycontroller 2 Battery Replacement
  1. Parrot Skycontroller 2 Battery Replacement, Battery: step 1, image 1 of 3 Parrot Skycontroller 2 Battery Replacement, Battery: step 1, image 2 of 3 Parrot Skycontroller 2 Battery Replacement, Battery: step 1, image 3 of 3
    • Flip your controller face down.
  2. Parrot Skycontroller 2 Battery Replacement: step 2, image 1 of 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Battery Replacement: step 3, image 1 of 3 Parrot Skycontroller 2 Battery Replacement: step 3, image 2 of 3 Parrot Skycontroller 2 Battery Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Battery Replacement: step 4, image 1 of 3 Parrot Skycontroller 2 Battery Replacement: step 4, image 2 of 3 Parrot Skycontroller 2 Battery Replacement: step 4, image 3 of 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 Battery Replacement: step 5, image 1 of 2 Parrot Skycontroller 2 Battery Replacement: step 5, image 2 of 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 19
All Time: 3,169
