Patagonia Backpack - C-Clamp Sternum Strap Replacement
  1. Patagonia Backpack - C-Clamp Sternum Strap Replacement, Sternum Strap (C-Clamp style): step 1, image 1 of 2 Patagonia Backpack - C-Clamp Sternum Strap Replacement, Sternum Strap (C-Clamp style): step 1, image 2 of 2
    • Locate a proper Sternum Strap replacement. Reach out to Patagonia if you need a replacement.
  2. Patagonia Backpack - C-Clamp Sternum Strap Replacement: step 2, image 1 of 3 Patagonia Backpack - C-Clamp Sternum Strap Replacement: step 2, image 2 of 3 Patagonia Backpack - C-Clamp Sternum Strap Replacement: step 2, image 3 of 3
    • At the bottom of the Sternum Strap "Rail" there is a flap.
    • Pull this flap back to expose the bottom of the Rail.
    • Slide the C-Clamp Clip back onto the Rail.
    • The C-Clamp can be difficult to slide on. You can pull the fabric that is around the Rail tightly to make this step easier.
    • Repeat the steps above on the other backpack strap.
  3. Patagonia Backpack - C-Clamp Sternum Strap Replacement: step 3, image 1 of 2 Patagonia Backpack - C-Clamp Sternum Strap Replacement: step 3, image 2 of 2
    • Slide the Sternum Strap to your desired position.
    • Hit the trails with your newly attached Sternum Strap!
Finish Line
Zach Mueller
748 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 112
All Time: 1,185
