Pebble Steel Watch Band Replacement
  1. Pebble Steel Watch Band Replacement, Watch Band: step 1, image 1 of 1
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $5.49
    Buy
    • Place the watch on its side to expose the side pins.
    • Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
  2. Pebble Steel Watch Band Replacement: step 2, image 1 of 1
    • Pull the pin out to remove the band.
  3. Pebble Steel Watch Band Replacement: step 3, image 1 of 1
    • Turn the watch to the other side and repeat steps 1 and 2 to remove the other band.
3 other people completed this guide.
MTS
948 Reputation
2 Guides authored
USF Tampa, Team 1-7, Leahy Fall 2015 Member of USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Members
7 Guides authored
1 Guide Comment
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
Christopher - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 2,737
