Pebble Steel failure of screen
  1. Pebble Steel failure of screen, Disassemble Strap: step 1, image 1 of 1
    • The first step is to remove the strap. To do this, we will use a 1.5mm flathead screwdriver.
  2. Pebble Steel failure of screen, Remove back cover: step 2, image 1 of 2 Pebble Steel failure of screen, Remove back cover: step 2, image 2 of 2
    • We will disassemble the cover of the clock using a screwdriver T-5, and being careful with the rubber gasket that has, we will remove the metallic cover.
  3. Pebble Steel failure of screen, Find and cut a soft rubber: step 3, image 1 of 2 Pebble Steel failure of screen, Find and cut a soft rubber: step 3, image 2 of 2
    • In this step we will look for a dissipative silicone of those that carry the laptops for the microprocessor. If you do not have it, you could use a piece of soft rubber that does not exceed 0.65mm thick.
  4. Pebble Steel failure of screen, Place rubber: step 4, image 1 of 2 Pebble Steel failure of screen, Place rubber: step 4, image 2 of 2
    • We will place this rubber in the lower right corner of the watch, on the vibrator and the connector of the screen. The golden connector on the left must be left free since it makes contact with the lid.
  5. Pebble Steel failure of screen, Close and READY !!!!: step 5, image 1 of 1
    • Finally we assemble the clock reversing the steps. '++ It is important when placing the cover to put first the two screws above and then the two screws below.' (This forces the entire internal chassis, thus exerting a pressure on the rubber contact of the screen.)
For reassembling your device, follow these instructions in the reverse order.
3 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marcos Garcia
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 1,615
