Pebble Time Battery Replacement
  1. Pebble Time Battery Replacement, Screen Cover: step 1, image 1 of 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Battery Replacement: step 2, image 1 of 2 Pebble Time Battery Replacement: step 2, image 2 of 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Battery Replacement: step 3, image 1 of 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Battery Replacement: step 4, image 1 of 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Battery Replacement, Screen: step 5, image 1 of 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Battery Replacement: step 6, image 1 of 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Battery Replacement: step 7, image 1 of 3 Pebble Time Battery Replacement: step 7, image 2 of 3 Pebble Time Battery Replacement: step 7, image 3 of 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Battery Replacement, Circuit Board: step 8, image 1 of 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Battery Replacement: step 9, image 1 of 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Battery Replacement: step 10, image 1 of 3 Pebble Time Battery Replacement: step 10, image 2 of 3 Pebble Time Battery Replacement: step 10, image 3 of 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Battery Replacement: step 11, image 1 of 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Battery Replacement: step 12, image 1 of 2 Pebble Time Battery Replacement: step 12, image 2 of 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Battery Replacement, Battery: step 13, image 1 of 1
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Battery Replacement: step 14, image 1 of 2 Pebble Time Battery Replacement: step 14, image 2 of 2
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Battery Replacement: step 15, image 1 of 2 Pebble Time Battery Replacement: step 15, image 2 of 2
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
34 other people completed this guide.
Nicolas Hempe
1,492 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2017 Member of USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Members
10 Guides authored
12 Guide Comments
Where did you purchase the replacement battery?
Dimas Caparros - Reply
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - Reply
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - Reply
Past 24 Hours: 9
Past 7 Days: 66
Past 30 Days: 323
All Time: 25,851
