Pentax ME Super Shutter Service
  1. Pentax ME Super Shutter Service, Remove wind lever: step 1, image 1 of 3 Pentax ME Super Shutter Service, Remove wind lever: step 1, image 2 of 3 Pentax ME Super Shutter Service, Remove wind lever: step 1, image 3 of 3
    • Wrap a piece of masking tape around your thumb, sticky side out.
    • Turn the wind lever cap clockwise to remove (it is reverse threaded).
    • Remove the wind lever lock ring (it is also reverse threaded).
    • Remove the brass spring washer.
    • A pair of fine tipped pliers or nippers can be used in place of a spanner wrench. Be careful!
  2. Pentax ME Super Shutter Service, Remove rewind lever: step 2, image 1 of 3 Pentax ME Super Shutter Service, Remove rewind lever: step 2, image 2 of 3 Pentax ME Super Shutter Service, Remove rewind lever: step 2, image 3 of 3
    • Place a tool in the fork of the rewind spindle.
    • Unscrew the rewind lever.
    • Remove the lock ring with a spanner.
    • Lift off the ISO/Exposure Compensation dial.
  3. Pentax ME Super Shutter Service, Installation Notes: ISO dial: step 3, image 1 of 1
    • Ensure that the ISO dial couples with the tab on the resistor.
    • Turn the Exposure Compensation to 1/4x then back to 4x while gently pushing down. This will help the dial engage with the detent mechanism properly.
  4. Pentax ME Super Shutter Service, Unscrew top cover: step 4, image 1 of 3 Pentax ME Super Shutter Service, Unscrew top cover: step 4, image 2 of 3 Pentax ME Super Shutter Service, Unscrew top cover: step 4, image 3 of 3
    • Remove two 3.3 mm #00 screws.
    • Remove one 3.2 mm #00 screw.
    • Remove one 2.6 mm #00 screw.
  5. Pentax ME Super Shutter Service, Unscrew top cover: step 5, image 1 of 2 Pentax ME Super Shutter Service, Unscrew top cover: step 5, image 2 of 2
    • Remove two 4.3 mm #00 screws.
  6. Pentax ME Super Shutter Service: step 6, image 1 of 2 Pentax ME Super Shutter Service: step 6, image 2 of 2
    • Lift off the top cover. The silver trim piece is loose and may fall away.
    • Remove loose washer.
  7. Pentax ME Super Shutter Service, Installation Notes: Top Cover: step 7, image 1 of 1
    • The shutter pin is loose. Make sure it is in place before installing the top cover.
    • The mode dial pin must be properly coupled with the mechanisms in the camera for it to work.
    • Set the mode dial to 'M'. Place the top cover on the camera. Move the mode dial to 'B' then back to 'M' while gently pushing down.
    • The mode dial should click into place and work properly.
  8. Pentax ME Super Shutter Service, Remove self-timer lever: step 8, image 1 of 3 Pentax ME Super Shutter Service, Remove self-timer lever: step 8, image 2 of 3 Pentax ME Super Shutter Service, Remove self-timer lever: step 8, image 3 of 3
    • Use a spanner or tweezers to remove remove self-timer screw. It is reverse threaded.
    • Remove self-timer lever.
    • Remove black spacer.
    • Remove spring washer.
  9. Pentax ME Super Shutter Service, Remove bottom cover: step 9, image 1 of 2 Pentax ME Super Shutter Service, Remove bottom cover: step 9, image 2 of 2
    • Remove two 3.0 mm #00 screws.
    • Remove one 2.1 mm #00 screw.
    • Remove loose plastic cover for motor drive pins.
  10. Pentax ME Super Shutter Service, Remove ISO resistor: step 10, image 1 of 3 Pentax ME Super Shutter Service, Remove ISO resistor: step 10, image 2 of 3 Pentax ME Super Shutter Service, Remove ISO resistor: step 10, image 3 of 3
    • Unsolder two yellow wires.
    • Remove one 3.0 mm #00 screw.
    • Remove one 5.9 mm flat head screw.
    • Lift off ISO resistor.
  11. Pentax ME Super Shutter Service, Unsolder left side connections: step 11, image 1 of 1
    • Unsolder one red wire (positive battery).
    • Unsolder one pink wire.
    • Unsolder one purple wire.
  12. Pentax ME Super Shutter Service, Unsolder right side connections: step 12, image 1 of 2 Pentax ME Super Shutter Service, Unsolder right side connections: step 12, image 2 of 2
    • Unsolder the red and blue wires (positive battery). They may share a pad.
    • Unsolder one gray wire.
    • Unsolder one white wire.
    • Unsolder one brown wire.
    • Unsolder one metal contact.
    • The wiring in this area varies with ME Supers from different production years. You may need to document the wiring for your own camera separately.
  13. Pentax ME Super Shutter Service, Unsolder motor winder connections: step 13, image 1 of 1
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one red wire.
    • On some cameras the wiring order may be green/red/blue.
  14. Pentax ME Super Shutter Service, Remove front leatherette: step 14, image 1 of 3 Pentax ME Super Shutter Service, Remove front leatherette: step 14, image 2 of 3 Pentax ME Super Shutter Service, Remove front leatherette: step 14, image 3 of 3
    • Apply isopropyl alcohol to soften the leatherette adhesive.
    • Use a dull scraper to left the edge of the covering.
    • Peel the leatherette away and remove it from both sides of the camera front.
    • Installation Notes: Use contact cement to reapply the leatherette. This should be the very last step in reassembly, after the camera is tested and functionality is confirmed.
  15. Pentax ME Super Shutter Service, Remove mirror box screws: step 15, image 1 of 3 Pentax ME Super Shutter Service, Remove mirror box screws: step 15, image 2 of 3 Pentax ME Super Shutter Service, Remove mirror box screws: step 15, image 3 of 3
    • Remove two 3.4 mm #00 screws.
    • Remove flex PCB retainer.
    • Remove shim washers. Note the location (left or right) and install in the same positions during reassembly.
  16. Pentax ME Super Shutter Service, Unscrew front plate: step 16, image 1 of 2 Pentax ME Super Shutter Service, Unscrew front plate: step 16, image 2 of 2
    • Remove four 4.0 mm #0 screws.
  17. Pentax ME Super Shutter Service, Remove front block assembly: step 17, image 1 of 2 Pentax ME Super Shutter Service, Remove front block assembly: step 17, image 2 of 2
    • Temporarily replace the advance lever and cock the shutter.
    • Gently lift the front block away from the camera body. Move slowly and look for wire snags.
  18. Pentax ME Super Shutter Service, Installation Notes: Front Block: step 18, image 1 of 1
    • Cock the shutter on the camera body. The mirror box should be uncharged before installation.
    • Twist the three motor drive wires together to easily insert them through the bottom of the camera.
    • Carefully track wire routing during installation. Make sure nothing is getting pinched and that all wires are accessible for resoldering.
    • Once the front block is in place, check the mechanical speeds of the shutter before completing the reassembly. The mirror and shutter should function normally.
  19. Pentax ME Super Shutter Service, Remove battery compartment: step 19, image 1 of 1
    • Remove two 3.8 mm #00 screws.
    • Remove battery compartment.
  20. Pentax ME Super Shutter Service, Remove shutter cocked indicator: step 20, image 1 of 1
    • Remove one 6.3 mm flat head screw.
    • Remove the shutter cocked indicator.
  21. Pentax ME Super Shutter Service, Remove frame counter assembly: step 21, image 1 of 3 Pentax ME Super Shutter Service, Remove frame counter assembly: step 21, image 2 of 3 Pentax ME Super Shutter Service, Remove frame counter assembly: step 21, image 3 of 3
    • Remove one 5.1 mm flat head screw.
    • Remove frame number indicator.
    • Unhook spring.
    • Remove one 3.9 mm #00 screw.
    • Carefully remove frame counter assembly.
  22. Pentax ME Super Shutter Service, Installation Notes: Frame counter assembly: step 22, image 1 of 3 Pentax ME Super Shutter Service, Installation Notes: Frame counter assembly: step 22, image 2 of 3 Pentax ME Super Shutter Service, Installation Notes: Frame counter assembly: step 22, image 3 of 3
    • Make sure the silver cam is fully inserted and in the correct position.
    • Insert these levers first. Then gently work the rest of the assembly into place.
    • Make sure the bias springs are placed properly.
  23. Pentax ME Super Shutter Service, Remove shutter block: step 23, image 1 of 3 Pentax ME Super Shutter Service, Remove shutter block: step 23, image 2 of 3 Pentax ME Super Shutter Service, Remove shutter block: step 23, image 3 of 3
    • Remove shutter light seal.
    • Remove three 3.4 mm #00 screws.
    • Swing the right side of the shutter forward, then lift out.
    • Cock the shutter by pushing the lever on the bottom to the left.
    • Push the shutter release on the bottom of the shutter begin the exposure.
    • Push the white plastic lever to the right release the closing curtain.
    • Hold the white plastic lever to the right to operate the shutter at its mechanical speed, 1/125.
    • The shutter should be in its released state for disassembly.
  24. Pentax ME Super Shutter Service, Remove shutter back plate: step 25, image 1 of 3 Pentax ME Super Shutter Service, Remove shutter back plate: step 25, image 2 of 3 Pentax ME Super Shutter Service, Remove shutter back plate: step 25, image 3 of 3
    • Peel off two foam light seals.
    • Remove four 2.3 mm #000 screws.
    • Remove back plate.
    • Remove top spacer.
    • Installation Notes: The light seal foam should be replaced with new foam during reassembly.
  25. Pentax ME Super Shutter Service, Remove closing curtain: step 26, image 1 of 3 Pentax ME Super Shutter Service, Remove closing curtain: step 26, image 2 of 3 Pentax ME Super Shutter Service, Remove closing curtain: step 26, image 3 of 3
    • Unhook helper spring.
    • Remove closing curtain linkage.
    • Remove five individual curtain blades.
  26. Pentax ME Super Shutter Service, Remove curtain separator: step 27, image 1 of 2 Pentax ME Super Shutter Service, Remove curtain separator: step 27, image 2 of 2
    • Remove curtain separator.
    • Remove bottom spacer.
  27. Pentax ME Super Shutter Service, Remove opening curtain: step 28, image 1 of 3 Pentax ME Super Shutter Service, Remove opening curtain: step 28, image 2 of 3 Pentax ME Super Shutter Service, Remove opening curtain: step 28, image 3 of 3
    • Remove three individual curtain blades.
    • Remove the opening curtain linkage.
    • Remove two curtain guides.
  28. Pentax ME Super Shutter Service, Clean the shutter: step 29, image 1 of 2 Pentax ME Super Shutter Service, Clean the shutter: step 29, image 2 of 2
    • Remove two degraded rubber bumpers. Clean the surrounding area with isopropyl alcohol.
    • Clean the two main pivot points for the opening and closing curtains.
    • Clean the contact surface of the closing curtain electromagnet.
Before reinstalling the shutter block, consider replacing the old foam seals on the camera chassis. With the fragile shutter curtains removed from the camera, it's easier to scrape and clean crumbling foam. The long strip along the edge of the shutter and the seals around the edge of the film door usually need replacing.
3 other people completed this guide.
Sam Gustafson
10,404 Reputation
57 Guides authored
9 Guide Comments
Thank you for this. I think I must be crazy doing this as my first camera repair attempt. I had dirt and oil all over my shutter blades and it was jamming every shot.
I managed to get through every step... until... Trying to resolder those short wires to the mirror box (the ones with the metal ribbon amongst them, near the frame counter). If you have any tips on actually managing to do this it'd be much appreciated.
cavjer123 - Reply
Yeah, this is the crux, the trickiest part. I like to lay the camera on the lens mount with top towards the soldering hand and the bottom towards my tweezers hand. I start with the wire closest to the lens mount. Get it in place with my tweezers as best I can, then sneak the soldering iron in just long enough to reflow the solder. Just be patient, you'll get it.
Sam Gustafson -
Hi. On step 29, you mention that degraded rubber parts should be removed. But do you replace them with something else? What is the consequence of removing them? A little more sound from the shutter or more wear to the shutter blades?
Stig Vidar Hovland - Reply
Honestly, I can't say what their specific purpose is other than some sort of damping. There are still two larger rubber bumpers on the bottom of the shutter that catch the edges of the curtains. Those do most of the work of stopping the blades without damaging them. I've tried both approaches, replacing the dampers with homemade parts and leaving them absent, and haven't been able to identify any differences in performance. The recommendation to leave them comes from that experience as well as comments I've seen other repairers make when they service this shutter. From what I can tell, they are supposed to be T-shaped and about 1 mm thick, in case you want to make a replacement.
Sam Gustafson -
Hello Sam, thank you for a very detail explanation on how to get these specific parts.....however my question is about when it goes all back together.....is there any way you could do a step by step of that? How the mirror box should be before it goes together.......even the firing sequence for the shutter blades....
When I did put it together the shutter button when pressed down.... it didn't fire....maybe i missed something.......
Hopefully you can help out?.......Thank you again for your time....
Ashok Lad - Reply
Past 24 Hours: 11
Past 7 Days: 63
Past 30 Days: 230
All Time: 2,686
