Pentax Optio WG-2 Battery Compartment Door Replacement
  1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: step 1, image 1 of 2 Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: step 1, image 2 of 2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: step 2, image 1 of 1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: step 4, image 1 of 3 Pentax Optio WG-2 Battery Compartment Door Replacement: step 4, image 2 of 3 Pentax Optio WG-2 Battery Compartment Door Replacement: step 4, image 3 of 3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: step 5, image 1 of 1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: step 6, image 1 of 1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: step 7, image 1 of 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: step 7, image 2 of 3 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: step 7, image 3 of 3
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
Matthew Bessette
658 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 799
