Pentax Optio WG-2 Memory Card Replacement
  1. Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 3 of 3
    • Make sure the camera is turned off before removing or inserting the SD Memory Card.
    • Press the lock lever (small tab) in an upward direction towards the word open.
    • Slide the cover away from the camera.
    • Lift the cover up to gain access to the memory card.
  2. Pentax Optio WG-2 Memory Card Replacement: step 2, image 1 of 2 Pentax Optio WG-2 Memory Card Replacement: step 2, image 2 of 2
    • To remove the SD Memory Card, push it in once and then pull it out.
Chris Gudiel
123 Reputation
1 Guide authored
USF Tampa, Team 1-4, Sullivan Spring 2017 Member of USF Tampa, Team 1-4, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G4
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 598
