Pentax Optio WG-3 GPS Motherboard Replacement
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: step 2, image 1 of 1
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: step 3, image 1 of 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: step 4, image 1 of 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: step 5, image 1 of 1
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: step 6, image 1 of 1
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: step 7, image 1 of 1
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: step 8, image 1 of 1
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: step 9, image 1 of 1
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: step 10, image 1 of 1
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: step 11, image 1 of 1
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: step 12, image 1 of 1
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: step 13, image 1 of 1
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: step 14, image 1 of 1
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
Garrett Rose
373 Reputation
2 Guides authored
IUPUI, Team 3-1, Harley Spring 2022 Member of IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 247
