Performance Tool W50042 Trigger Switch Replacement
  1. Performance Tool W50042 Trigger Switch Replacement, Trigger Switch: step 1, image 1 of 1
    • Remove the battery by pressing the yellow tabs on both sides, then pull the battery out.
  2. Performance Tool W50042 Trigger Switch Replacement: step 2, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 2, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 2, image 3 of 3
    • Remove the nine 1/2 inch Phillips head screws.
  3. Performance Tool W50042 Trigger Switch Replacement: step 3, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 3, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 3, image 3 of 3
    • Use a T-25 hex bit to remove four 1'1/2 hex head screws.
  4. Performance Tool W50042 Trigger Switch Replacement: step 4, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 4, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 4, image 3 of 3
    • Remove the shaft cover.
  5. Performance Tool W50042 Trigger Switch Replacement: step 5, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 5, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 5, image 3 of 3
    • Remove the case.
  6. Performance Tool W50042 Trigger Switch Replacement: step 6, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 6, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 6, image 3 of 3
    • Lift the trigger switch to remove the direction switch.
  7. Performance Tool W50042 Trigger Switch Replacement: step 7, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 7, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 7, image 3 of 3
    • Unscrew the red wire from the motor (Phillips head screw 1/4 inch).
  8. Performance Tool W50042 Trigger Switch Replacement: step 8, image 1 of 3 Performance Tool W50042 Trigger Switch Replacement: step 8, image 2 of 3 Performance Tool W50042 Trigger Switch Replacement: step 8, image 3 of 3
    • Pick up the motor and remove the black wire (Phillips head screw 1/4 inch).
David
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 154
