Petmate 29027 Fountain Lid and Pump Replacement
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: step 1, image 1 of 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: step 1, image 2 of 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: step 1, image 3 of 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: step 2, image 1 of 3 Petmate 29027 Fountain Lid and Pump Replacement: step 2, image 2 of 3 Petmate 29027 Fountain Lid and Pump Replacement: step 2, image 3 of 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: step 3, image 1 of 2 Petmate 29027 Fountain Lid and Pump Replacement: step 3, image 2 of 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: step 4, image 1 of 3 Petmate 29027 Fountain Lid and Pump Replacement: step 4, image 2 of 3 Petmate 29027 Fountain Lid and Pump Replacement: step 4, image 3 of 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: step 5, image 1 of 2 Petmate 29027 Fountain Lid and Pump Replacement: step 5, image 2 of 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: step 6, image 1 of 2 Petmate 29027 Fountain Lid and Pump Replacement: step 6, image 2 of 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Finish Line
Shidie Ren
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 519
