Petzl E03 050 Headlamp Mount Assembly Replacement
  1. Petzl E03 050 Headlamp Mount Assembly Replacement, Examine the Mount Assembly: step 1, image 1 of 1
    • Check the mount assembly for a loose or missing nut and/or bolt.
  2. Petzl E03 050 Headlamp Mount Assembly Replacement, Remove the Old Nut & Bolt: step 2, image 1 of 1
    • Remove the old nut and bolt by using a Phillips head screwdriver to rotate the bolt counterclockwise until it becomes free. The nut should become free on its own as the bolt is removed. If it doesn't, poke the nut out using the screwdriver.
  3. Petzl E03 050 Headlamp Mount Assembly Replacement, Insert New Nut: step 3, image 1 of 1
    • Insert the new nut by placing it in the left side of the circular hole created after the removal of the old nut & bolt in step 2.
  4. Petzl E03 050 Headlamp Mount Assembly Replacement, Insert the New Bolt: step 4, image 1 of 1
    • Insert the threaded portion of the new bolt with the washer into the right side of the circular hole created by the removal of the old nut & bolt in step #2.
  5. Petzl E03 050 Headlamp Mount Assembly Replacement, Hold the Nut: step 5, image 1 of 1
    • Firmly hold the nut in place with your left thumb such that the nut will not rotate.
  6. Petzl E03 050 Headlamp Mount Assembly Replacement, Tighten the Bolt: step 6, image 1 of 1
    • Tighten the new bolt into the new nut by turning the bolt clockwise using a Phillips head screwdriver until the bolt & nut are tight.
Finish Line
Mike
331 Reputation
3 Guides authored
Baylor, Team 8-10, Williams Fall 2014 Member of Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 13
All Time: 462
