Pfaff Tiptronic 2020 Cleaning
  1. Pfaff Tiptronic 2020 Cleaning, Remove screws: step 1, image 1 of 1
    Tool used on this step:
    Mahi Driver Kit - 48 Bit Driver Kit
    $39.95
    Buy
    • The top cover is only held in place by a screw (Torx T25H) with washer. The screw is not screwed into the cover, but only clamps it in place (with the washer).
    • To see the screw, fold up the handle of the sewing machine. The screw is located approximately in the middle of the back half of the gap between the sewing machine arm and the cover on the left.
    • Use a Torx T25H screwdriver to loosen the screw.
    • Unfortunately, the bit holder of the Mahi Precision Bit Set does not fit into the narrow slot, so you need a screwdriver with a long blade. If you don't have one, you can squeeze the blunt tweezers and use them like a slotted screwdriver, which worked very well for me.
  2. Pfaff Tiptronic 2020 Cleaning, Open housing cover: step 2, image 1 of 3 Pfaff Tiptronic 2020 Cleaning, Open housing cover: step 2, image 2 of 3 Pfaff Tiptronic 2020 Cleaning, Open housing cover: step 2, image 3 of 3
    • Open the cover as if you were opening a book.
    • The cover is not attached with a hinge (or anything else) at the back, so hold it firmly.
    • At the back runs the cable for the sewing light; be careful not to accidentally tear it off.
    • Release the cable for the sewing light from its 4 retaining clips on the inside of the cover with your fingers.
    • Place the cover on the sewing machine arm so that the cable is not strained.
  3. Pfaff Tiptronic 2020 Cleaning, Reattach the cover: step 3, image 1 of 2 Pfaff Tiptronic 2020 Cleaning, Reattach the cover: step 3, image 2 of 2
    • To be able to reattach the cover later, align it with the housing and reinsert the cable for the sewing light into the four retaining clips.
    • Loosen the screw that clamps the cover a little more.
    • Slide the washer up to the screw head so that you can slide the plastic part of the cover underneath it. You may have to hold the washer up while doing this. This is a bit tricky; it works quite well with the pointed tweezers.
    • Replace the cover and push it as close as possible to the right side of the sewing machine arm.
    • Use a Torx T25H screwdriver (or the blunt tweezers) to retighten the screw.
  4. Pfaff Tiptronic 2020 Cleaning, Cleaning the upper mechanism: step 4, image 1 of 3 Pfaff Tiptronic 2020 Cleaning, Cleaning the upper mechanism: step 4, image 2 of 3 Pfaff Tiptronic 2020 Cleaning, Cleaning the upper mechanism: step 4, image 3 of 3
    Anti-Static Brush
    $2.99
    Buy
    • Use a (hand) hoover with the narrowest possible brush attachment to remove the coarsest dust.
    • If you don't have this attachment, brushing the dust into a lower placed hoover can be a viable alternative.
    • Then take a narrow cleaning brush with long bristles to clean the mechanism thoroughly from all sides.
    • The cleaning brush with long bristles from iFixit is really very well suited for this. The bristles are long and can reach everywhere, the brush is narrow so that you can also reach hidden corners easily. The bristles don't fall out, as easily happens with hair brushes, they don't scratch, but they are stable enough to remove dirt well.
    • Coarse or stuck dust particles can be fished out easily with long, narrow, pointed tweezers.
    • While cleaning, turn the handwheel and the thread tension wheel back and forth to catch as much dust as possible.
  5. Pfaff Tiptronic 2020 Cleaning: step 5, image 1 of 2 Pfaff Tiptronic 2020 Cleaning: step 5, image 2 of 2
    • Vacuum up everything again with the hoover.
    • Then take a dust blower and blow air from different angles against the mechanism
    • The dust blower should only be used when most of the dust has already been removed. Otherwise, you risk pushing the dust even deeper into the housing.
    • Repeat these last steps, until the mechanism is clean again and there is no dust falling off or stuck inside it.
  6. Pfaff Tiptronic 2020 Cleaning, Cleaning the lower mechanism: step 6, image 1 of 3 Pfaff Tiptronic 2020 Cleaning, Cleaning the lower mechanism: step 6, image 2 of 3 Pfaff Tiptronic 2020 Cleaning, Cleaning the lower mechanism: step 6, image 3 of 3
    Spudger
    $3.99
    Buy
    • If you have not already done so, remove the needle, presser foot and bobbin case with the bobbin thread. Remove the sewing table.
    • The needle plate is only held by two clips. Using a flat-blade screwdriver or iFixit spudger, lift up first the right and then the left side of the needle plate to remove it.
    • Lower the feed dog by sliding the switch next to the thread cap towards the right.
  7. Pfaff Tiptronic 2020 Cleaning: step 7, image 1 of 3 Pfaff Tiptronic 2020 Cleaning: step 7, image 2 of 3 Pfaff Tiptronic 2020 Cleaning: step 7, image 3 of 3
    • Clean everything thoroughly with the brush: run it through the recesses under the needle plate and around the hook.
    • Tweezers also do a good job here to get out larger dust clumps or stuck dust flakes.
  8. Pfaff Tiptronic 2020 Cleaning, To end it off: step 8, image 1 of 3 Pfaff Tiptronic 2020 Cleaning, To end it off: step 8, image 2 of 3 Pfaff Tiptronic 2020 Cleaning, To end it off: step 8, image 3 of 3
    • Put the needle plate back in place. Press it down centrally at the back and front and the clips will snap back into place.
    • Now add a drop of sewing machine oil in the hook at the place marked in picture 3 and the machine will be happy again!
    • Replace needle, presser foot and bobbin case.
    • Don't forget to set the upper thread tension correctly again.
    • You are done! Have fun sewing!
Follow the steps in reverse order to reassemble your device. Have fun sewing!
Special thanks to these translators:
de en
100%
carlotremolada is helping us fix the world! Want to contribute?
Start translating ›
Maria Parker
18,189 Reputation
10 Guides authored
German Translators Member of German Translators
Community
35 Members
1,216 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 86
All Time: 1,333
