Philips BiPAP S/T Blower Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Video Overview
  1. Philips BiPAP S/T Blower  Replacement, Blower: step 1, image 1 of 1
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: step 2, image 1 of 1
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: step 3, image 1 of 1
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: step 4, image 1 of 1
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: step 7, image 1 of 1
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
2 other people completed this guide.
Benjamin LaVigna
243 Reputation
1 Guide authored
Cal Poly, Team S7-G3, Paton Spring 2020 Member of Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 Members
3 Guides authored
4 Guide Comments
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Reply
Great guide on replacing the blower assembly! It's essential to ensure that every component, like the Tournevis Torx tools, is in top shape to avoid any malfunctions. Just as in Geometry Dash, where precision is key to overcoming obstacles, the same meticulous attention is needed here. Ensure you follow each step carefully to maintain your unit's performance.
LucinaAvery - Reply
This detailed guide on replacing the Philips BiPAP S/T blower is very helpful for anyone facing device malfunction due to blower wear. The step-by-step instructions and tool list ensure a smooth repair process. For those who enjoy challenges, trying the Sprunki game can offer a fun break while awaiting parts. Keeping your equipment in top shape is crucial, and this clear guide makes the task manageable for most users.
OscarLarnach - Reply
Hanya kebohongan dan taktik penipuan. Buang-buang waktu dan uang saja.
Situs Penipuan sialan
lipok - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,166
