Philips BiPAP S/T Humidifier Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Philips BiPAP S/T Humidifier Replacement, Humidifier: step 1, image 1 of 1
    • Remove the Water Chamber Assembly.
    • Gently squeeze the latch on the Flip Lid Assembly to release it.
    • Lift the Flip Lid Assembly.
    • Pull the Humidifier Tank Assembly out of the Humidifier.
  2. Philips BiPAP S/T Humidifier Replacement: step 2, image 1 of 1
    • Remove the Tank Top Seal from the Flip Lid Assembly.
    • If this is the source of the error, put in a new one.
  3. Philips BiPAP S/T Humidifier Replacement: step 3, image 1 of 2 Philips BiPAP S/T Humidifier Replacement: step 3, image 2 of 2
    • Remove the Dry Box Seal.
    • If this is the source of error, place this part with a new one.
    • When replacing, ensure that the narrow end of the seal is inserted into the Dry Box.
  4. Philips BiPAP S/T Humidifier Replacement: step 4, image 1 of 2 Philips BiPAP S/T Humidifier Replacement: step 4, image 2 of 2
    • Remove the Dry Box Assembly.
    • Insert a flat blade screwdriver into the hole located on the back of the Humidifier and lightly press inward to release the Dry Box Assembly.
    • Do not press firmly on the screwdriver as damage may occur.
    • Remove the Inlet Seal from the Dry Box Assembly
  5. Philips BiPAP S/T Humidifier Replacement: step 5, image 1 of 3 Philips BiPAP S/T Humidifier Replacement: step 5, image 2 of 3 Philips BiPAP S/T Humidifier Replacement: step 5, image 3 of 3
    • Remove the Flip Lid Assembly.
    • Use a screwdriver to push in on the latches that secure the Flip Lid Assembly to the Humidifier Top Housing.
    • Bend the Flip Lid Assembly completely backwards until it is removed.
    • For Heated Tube devices, remove the wire harness from the base.
  6. Philips BiPAP S/T Humidifier Replacement: step 6, image 1 of 1
    • Use a T8 Torx screwdriver to remove the four #4 x 1/2" screws that secure the Top Housing to the Humidifier Bottom Housing
  7. Philips BiPAP S/T Humidifier Replacement: step 7, image 1 of 1
    • Slide the Outside Cover out of the Bottom Housing.
  8. Philips BiPAP S/T Humidifier Replacement: step 8, image 1 of 1
    • Remove the Left Side Panel.
    • Use a T15 Torx screwdriver to remove the four #6 x 1/4" screws that secure the Bottom Housing to the Lower Base Assembly.
  9. Philips BiPAP S/T Humidifier Replacement: step 9, image 1 of 2 Philips BiPAP S/T Humidifier Replacement: step 9, image 2 of 2
    • Remove the Heater Plate Assembly.
    • The Heater Plate Assembly is secured by two small tabs.
    • Once replaced, secure the Bottom Housing to the Lower Base using the four #6 x 1/4" screws.
    • Be sure the Heater Plate Spring is properly seated under the Heater Plate.
Courtney Huitt
169 Reputation
1 Guide authored
Cal Poly, Team S7-G3, Paton Spring 2020 Member of Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 418
