Philips Comfort 215 Iron Power Cord Replacement
  1. Philips Comfort 215 Iron Power Cord Replacement, remove screws: step 1, image 1 of 2 Philips Comfort 215 Iron Power Cord Replacement, remove screws: step 1, image 2 of 2
    • Philips Comfort 215 Iron:
    • Remove the two phillips screws at the back.
    • Remove the turning knob to reveal the third screw. The knob can be lifted once it is in the right orientation; it needs very little force.
    • The top cover can now be removed
  2. Philips Comfort 215 Iron Power Cord Replacement, releasing the wire, replacing: step 2, image 1 of 2 Philips Comfort 215 Iron Power Cord Replacement, releasing the wire, replacing: step 2, image 2 of 2
    • The connectors are held in place by a peg; release them by pushing a small lever in the middle of the connector.
    • Here the old connectors have been soldered to the new wire; the joint has been covered with heat-shrink tubing.
    • As always, take care that the wire is routed correctly through the top cover and entry guide before connecting everything
Pieter van der Wolk
859 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 451
