Philips DVP5992-F7 HDMI port Replacement
  1. Philips DVP5992-F7 HDMI port Replacement, HDMI port: step 1, image 1 of 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: step 1, image 2 of 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: step 1, image 3 of 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 HDMI port Replacement: step 2, image 1 of 2 Philips DVP5992-F7 HDMI port Replacement: step 2, image 2 of 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 HDMI port Replacement: step 3, image 1 of 3 Philips DVP5992-F7 HDMI port Replacement: step 3, image 2 of 3 Philips DVP5992-F7 HDMI port Replacement: step 3, image 3 of 3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 HDMI port Replacement: step 4, image 1 of 1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 HDMI port Replacement: step 5, image 1 of 1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 HDMI port Replacement: step 6, image 1 of 1
    • Remove the motherboard from the DVD player.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 281
