Philips DVP5992-F7 Power Cord Replacement
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: step 1, image 1 of 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: step 1, image 2 of 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: step 1, image 3 of 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: step 2, image 1 of 2 Philips DVP5992-F7 Power Cord Replacement: step 2, image 2 of 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: step 3, image 1 of 3 Philips DVP5992-F7 Power Cord Replacement: step 3, image 2 of 3 Philips DVP5992-F7 Power Cord Replacement: step 3, image 3 of 3
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 414
