Philips DVP5992-F7 Screen Replacement
  1. Philips DVP5992-F7 Screen Replacement, Screen: step 1, image 1 of 3 Philips DVP5992-F7 Screen Replacement, Screen: step 1, image 2 of 3 Philips DVP5992-F7 Screen Replacement, Screen: step 1, image 3 of 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Screen Replacement: step 2, image 1 of 2 Philips DVP5992-F7 Screen Replacement: step 2, image 2 of 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Screen Replacement: step 3, image 1 of 3 Philips DVP5992-F7 Screen Replacement: step 3, image 2 of 3 Philips DVP5992-F7 Screen Replacement: step 3, image 3 of 3
    • Unplug the bundled cable connector that attaches the screen to the motherboard.
    • Remove the 3.175 mm Phillips #1 screw that connects the screen's ground wire to the shell of the DVD player.
    • Remove the three 6.35 mm Phillips #1 screws that attach the screen to the front cover of the DVD player.
  4. Philips DVP5992-F7 Screen Replacement: step 4, image 1 of 2 Philips DVP5992-F7 Screen Replacement: step 4, image 2 of 2
    • Slowly pull the screen backwards starting with the side farthest from the disc tray.
    • Unplug the bundled cable connector that is located close to the disc tray as you pull the screen out of the DVD player.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 252
