Philips DVP5992-F7 Tray Replacement
  1. Philips DVP5992-F7 Tray Replacement, Tray: step 1, image 1 of 3 Philips DVP5992-F7 Tray Replacement, Tray: step 1, image 2 of 3 Philips DVP5992-F7 Tray Replacement, Tray: step 1, image 3 of 3
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: step 2, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 2, image 2 of 2
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: step 3, image 1 of 3 Philips DVP5992-F7 Tray Replacement: step 3, image 2 of 3 Philips DVP5992-F7 Tray Replacement: step 3, image 3 of 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: step 4, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 4, image 2 of 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: step 5, image 1 of 3 Philips DVP5992-F7 Tray Replacement: step 5, image 2 of 3 Philips DVP5992-F7 Tray Replacement: step 5, image 3 of 3
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: step 6, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 6, image 2 of 2
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: step 7, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 7, image 2 of 2
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: step 8, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 8, image 2 of 2
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: step 9, image 1 of 2 Philips DVP5992-F7 Tray Replacement: step 9, image 2 of 2
    • Lift the tray out of the DVD player from the back.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 516
