Introduction
In this guide you will locate screws and ribbon wires holding the motherboard in the player. After removal the motherboard itself can be repaired on the component level.
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Locate the first three ribbon wires.
Remove the ribbon wires by grasping firmly as near to the plastic head as possible and pulling.
Remove the following screws:
7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
Remove the 7.5 mm Phillips screw on the bottom right that attaches the grounding wire to the disc tray.
7.5 mm Phillips screws (4) on outside of player near input/output plugs.
6 other people completed this guide.
