Philips DVP642 Power Supply Replacement
  1. Philips DVP642 Power Supply Replacement, Top Panel: step 1, image 1 of 2 Philips DVP642 Power Supply Replacement, Top Panel: step 1, image 2 of 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: step 2, image 1 of 2 Philips DVP642 Power Supply Replacement: step 2, image 2 of 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: step 3, image 1 of 2 Philips DVP642 Power Supply Replacement, Power Supply: step 3, image 2 of 2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: step 4, image 1 of 1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: step 5, image 1 of 2 Philips DVP642 Power Supply Replacement: step 5, image 2 of 2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: step 6, image 1 of 2 Philips DVP642 Power Supply Replacement: step 6, image 2 of 2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: step 7, image 1 of 3 Philips DVP642 Power Supply Replacement: step 7, image 2 of 3 Philips DVP642 Power Supply Replacement: step 7, image 3 of 3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: step 8, image 1 of 2 Philips DVP642 Power Supply Replacement: step 8, image 2 of 2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
7 other people completed this guide.
Toby Goldsteinholm
360 Reputation
2 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 40
All Time: 13,464
