Philips DVP642 Top Panel Replacement
  1. Philips DVP642 Top Panel Replacement, Top Panel: step 1, image 1 of 2 Philips DVP642 Top Panel Replacement, Top Panel: step 1, image 2 of 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Top Panel Replacement: step 2, image 1 of 2 Philips DVP642 Top Panel Replacement: step 2, image 2 of 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
3 other people completed this guide.
Nathan Klammer
461 Reputation
3 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 968
