Philips HD9252 Latch Button Replacement
  1. Philips HD9252 Latch Button Replacement, Tray: step 1, image 1 of 1
    • Remove the tray from the air fryer by pressing the latch button in, and pulling the handle away.
  2. Philips HD9252 Latch Button Replacement: step 2, image 1 of 1
    • Pull the tray out of the basket.
  3. Philips HD9252 Latch Button Replacement, Latch Button: step 3, image 1 of 2 Philips HD9252 Latch Button Replacement, Latch Button: step 3, image 2 of 2
    • Remove the two 14.8 mm screws placed in the top of the latch using a Phillips #00 screwdriver.
    • Remove the two 14.8 mm screws placed on the bottom of the latch using a Phillips #00 screwdriver.
  4. Philips HD9252 Latch Button Replacement: step 4, image 1 of 1
    • Remove the four 14.8 mm screws placed on front of the latch button using a Phillips #00 screwdriver.
  5. Philips HD9252 Latch Button Replacement: step 5, image 1 of 1
    • Pry off the back panel of the handle.
  6. Philips HD9252 Latch Button Replacement: step 6, image 1 of 2 Philips HD9252 Latch Button Replacement: step 6, image 2 of 2
    • Push the spring down with a nylon spudger so that it is underneath the button.
    • Slide the spring out of the back of the handle.
  7. Philips HD9252 Latch Button Replacement: step 7, image 1 of 1
    • Remove the front of the latch from the handle.
  8. Philips HD9252 Latch Button Replacement: step 8, image 1 of 1
    • Remove the button through the back of the handle.
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 201
All Time: 1,803
