Philips Norelco 5801XL Battery Replacement
Ben Gibbs
Ben Gibbs and 4 other contributors
Last updated on July 15, 2024
10 - 25 minutes
Moderate
Missing Steps
Introduction
Go to step 1
Use this guide to replace the rechargeable battery in the Philips Norelco 5801XL. The steps should be followed exactly as listed in the guide. Some soldering skills are required. Be sure to handle with care. For help with soldering: click here.
Parts
Tools
Show more…
  1. Philips Norelco 5801XL Battery Replacement, Battery: step 1, image 1 of 2 Philips Norelco 5801XL Battery Replacement, Battery: step 1, image 2 of 2
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: step 2, image 1 of 2 Philips Norelco 5801XL Battery Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: step 3, image 1 of 3 Philips Norelco 5801XL Battery Replacement: step 3, image 2 of 3 Philips Norelco 5801XL Battery Replacement: step 3, image 3 of 3
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: step 4, image 1 of 1
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: step 5, image 1 of 1
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: step 6, image 1 of 1
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: step 7, image 1 of 3 Philips Norelco 5801XL Battery Replacement: step 7, image 2 of 3 Philips Norelco 5801XL Battery Replacement: step 7, image 3 of 3
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
3 other people completed this guide.
Ben Gibbs
361 Reputation
3 Guides authored
IUPUI, Team 3-2, Harley Spring 2016 Member of IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 Members
6 Guides authored
3 Comments
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Reply
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 4,376
