Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: step 1, image 1 of 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: step 1, image 2 of 2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 2, image 1 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 2, image 2 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 2, image 3 of 3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 3, image 1 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 3, image 2 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 3, image 3 of 3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 4, image 1 of 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 4, image 2 of 2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 5, image 1 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 5, image 2 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 5, image 3 of 3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 6, image 1 of 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 6, image 2 of 2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 7, image 1 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 7, image 2 of 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: step 7, image 3 of 3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
2 other people completed this guide.
August Post
415 Reputation
3 Guides authored
IUPUI, Team S2-G4, Harley Fall 2017 Member of IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Members
4 Guides authored
One Comment
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 547
