Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement
  1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: step 1, image 1 of 2 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: step 1, image 2 of 2
    • Pop open the trimmer head by pushing against the blades.
    • Slide off trimmer guard and open the hatch on the side.
    • Remove the trimmer from the base.
  2. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: step 2, image 1 of 2 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: step 2, image 2 of 2
    • Remove spring first, and then pull off white plastic along with the first, moving blade.
    • Use spudger to pry off second, stationary blade.
August Post
415 Reputation
3 Guides authored
IUPUI, Team S2-G4, Harley Fall 2017 Member of IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Members
4 Guides authored
One Comment
How do you reattach the spring?
Antonio Chrysokhou - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 3,536
