Philips Norelco BeardTrimmer 3100 Battery Replacement
  1. Philips Norelco BeardTrimmer 3100 Battery Replacement, Front and Back Panels: step 1, image 1 of 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 2, image 1 of 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 2, image 2 of 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 3, image 1 of 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 3, image 2 of 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 4, image 1 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 4, image 2 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 4, image 3 of 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 5, image 1 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 5, image 2 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 5, image 3 of 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 6, image 1 of 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 6, image 2 of 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 7, image 1 of 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 8, image 1 of 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 8, image 2 of 2
  9. Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: step 9, image 1 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: step 9, image 2 of 3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: step 9, image 3 of 3
    • Face the battery towards you.
    • Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
  10. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 10, image 1 of 1
    • Grab the battery by its sides, pull it upwards out of the base of the trimmer.
  11. Philips Norelco BeardTrimmer 3100 Battery Replacement: step 11, image 1 of 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: step 11, image 2 of 2
    • Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
    • Be careful when dealing with solder. The metals will become very hot and can cause damage to skin/clothing.
29 other people completed this guide.
Darren Chu
1,605 Reputation
3 Guides authored
USF Tampa, Team 15-2, Blackwell Fall 2015 Member of USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Members
8 Guides authored
20 Comments
Hi, what are the specs on the NiMh battery?
Eric Nguyen - Reply
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
galligant -
I think you can simply use a AA battery, 1.2V
Olivier Lefaux - Reply
Note: AA Alkaline battery is 1.5V and not rechargeable.
galligant -
Awesome work.very helpful
Himanshu sahrma - Reply
Past 24 Hours: 3
Past 7 Days: 45
Past 30 Days: 227
All Time: 70,959
