Philips Norelco BeardTrimmer 3100 Blade Replacement
  1. Philips Norelco BeardTrimmer 3100 Blade Replacement, Blade: step 1, image 1 of 1
    • Remove the comb from the head of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 2, image 1 of 2 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 2, image 2 of 2
    • Place thumb underneath the blade; push upward to pop the blade off.
  3. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 3, image 1 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 3, image 2 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Grab the plastic arms with the tweezers and pull them apart from the base.
  4. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 4, image 1 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 4, image 2 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 4, image 3 of 3
    • Remove the plastic casing from the underside of the blade.
  5. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 5, image 1 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 5, image 2 of 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 5, image 3 of 3
    • Remove the last plastic casing from the front side of the blade.
  6. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 6, image 1 of 2 Philips Norelco BeardTrimmer 3100 Blade Replacement: step 6, image 2 of 2
    • Pull the spring off from the base with the tweezers.
  7. Philips Norelco BeardTrimmer 3100 Blade Replacement: step 7, image 1 of 1
    • Pull the blade apart from the base with the tweezers.
21 other people completed this guide.
Darren Chu
1,605 Reputation
3 Guides authored
USF Tampa, Team 15-2, Blackwell Fall 2015 Member of USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Members
8 Guides authored
10 Comments
what about getting it back togeather
andrewv100 - Reply
Sadly it is impossible to put the parts back together. It isnt just as simple as start with the end. Normally i am quite good with fixing stuff. But this time... maybe because mine is broken? A guide for putting it back together should show me where it g9es wrong. But thanks for the guide anyways, thanks for the time you put into it.
Bart Teeuwen - Reply
Now I can't get it back :-(
AbdulJalil - Reply
Buy a new one. It not worth the time and effort unless you're trying to get away from the wife
zorba - Reply
It's easy to get it back.i assembled mine a lot of times... Guys just try
tarangill.zippy - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 80
All Time: 22,082
