Philips Norelco BeardTrimmer 3100 Handle Replacement
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: step 1, image 1 of 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 2, image 1 of 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 2, image 2 of 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 3, image 1 of 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 3, image 2 of 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 4, image 1 of 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 4, image 2 of 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 4, image 3 of 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 5, image 1 of 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 5, image 2 of 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 5, image 3 of 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 6, image 1 of 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 6, image 2 of 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 7, image 1 of 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: step 8, image 1 of 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: step 8, image 2 of 2
2 other people completed this guide.
filmon gebregergis
143 Reputation
1 Guide authored
USF Tampa, Team 15-2, Blackwell Fall 2015 Member of USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 5,622
