Philips Norelco Shaver 2100 Battery Replacement
Marshall MacClellan
Marshall MacClellan and 4 other contributors
Last updated on July 16, 2024
15 - 20 minutes
Moderate
Introduction
Go to step 1
Use this guide to replace the battery of your Philips Norelco 2100 as it may be defective.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Philips Norelco Shaver 2100 Battery Replacement, Casing: step 1, image 1 of 1
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Battery Replacement: step 2, image 1 of 2 Philips Norelco Shaver 2100 Battery Replacement: step 2, image 2 of 2
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Battery Replacement: step 3, image 1 of 1
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Battery Replacement: step 4, image 1 of 2 Philips Norelco Shaver 2100 Battery Replacement: step 4, image 2 of 2
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Battery Replacement: step 5, image 1 of 3 Philips Norelco Shaver 2100 Battery Replacement: step 5, image 2 of 3 Philips Norelco Shaver 2100 Battery Replacement: step 5, image 3 of 3
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Battery Replacement: step 6, image 1 of 3 Philips Norelco Shaver 2100 Battery Replacement: step 6, image 2 of 3 Philips Norelco Shaver 2100 Battery Replacement: step 6, image 3 of 3
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
  7. Philips Norelco Shaver 2100 Battery Replacement, Battery: step 7, image 1 of 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: step 7, image 2 of 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: step 7, image 3 of 3
    • Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
  8. Philips Norelco Shaver 2100 Battery Replacement: step 8, image 1 of 1
    • Located directly behind the circuit board, remove the battery from the device.
    Why is it so hard for me to get the battery out is there something that is holding it still
    Ben Grack - Reply
14 other people completed this guide.
Marshall MacClellan
419 Reputation
1 Guide authored
USF Tampa, Team S1-G4, Thompson Fall 2017 Member of USF Tampa, Team S1-G4, Thompson Fall 2017
USFT-THOMPSON-F17S1G4
3 Members
10 Guides authored
14 Comments
To remove the battery you have to actually desolder both ends from the chip.
AGUSTIN CABRA - Reply
What are the dimensions/specs of the battery?
Haley Pearse - Reply
regular AA rechargeable batteries will not work and can be a fire hazard.
steven - Reply
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
Don - Reply
I have a similar Norelco razor and replaced the battery. I can’t believe the stupid company didn’t mark the battery polarity on the board!
I think this is the first time I have ever seen a company not mark polarity.
Laz - Reply
This is very helpful indeed. Do you have any details of the type of battery used? This is a vital piece of information thank you!
Richard - Reply
Battery is a 14500 lithium ion battery. Polarity can be checked with a multimeter
Geobio Boo - Reply
my shaver (series 3000) has SONY US14500VR2 680mAh 3.7V battery, if that will help anyone
Tom Francuz - Reply
I’ve now disassembled two different Norelco shavers, and both, sadly, had soldered-in batteries.
I used to be an electronics tech decades ago, and have spent hundreds of hours with a soldering iron in my hands.
Unsoldering these batteries was difficult. Not much room. I ruined one shaver.
It’s often recommended not unsoldering the old battery from the little ckt board, to instead leave it connected but to clip the tab, then solder the new battery to the old tab. This worked for me, but again, not much room. A capacitor blocked access at one terminal.
Speaking of terminal, one person noted “the stupid company didn’t mark the battery polarity on the board.” This is true, but not an issue, as the new battery will go in the same way as the old one. On the two shavers I opened, both had the positive terminal closer to the blades.
The battery costs under ten dollars on Amazon. Seems a good investment for an old shaver.
Steve Kohn - Reply
Did you find a shorter length 14500 L/I battery that fit the 2100's battery holder. My original battery is only 43 mm long (tall), and the frame it sits in does not appear to allow anything longer.
TC53 -
چه جور میتونم چرخدنده مدل 5822 را تعویض کنم.
Ali Shahir fard - Reply
Thanks, I'm off to a thrift shop to find some fixits.
Stanley Willis - Reply
Excellent tutorial. Had it apart in five minutes. You have to de-solder the batteries from the circuit board though.
Roger Schultz - Reply
I've got my 2100 apart, but the original battery is only 42-43 mm in length and the frame it sits in will allow nothing longer. Most of the 14500 L/I batteries I'm seeing say they're 50 mm long. Has anyone found a short length 14500 that will fit these specs?
TC53 - Reply
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 156
All Time: 22,190
