Philips Norelco Shaver 2100 Casing Replacement
  1. Philips Norelco Shaver 2100 Casing Replacement, Casing: step 1, image 1 of 1
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Casing Replacement: step 2, image 1 of 2 Philips Norelco Shaver 2100 Casing Replacement: step 2, image 2 of 2
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Casing Replacement: step 3, image 1 of 1
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Casing Replacement: step 4, image 1 of 2 Philips Norelco Shaver 2100 Casing Replacement: step 4, image 2 of 2
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Casing Replacement: step 5, image 1 of 3 Philips Norelco Shaver 2100 Casing Replacement: step 5, image 2 of 3 Philips Norelco Shaver 2100 Casing Replacement: step 5, image 3 of 3
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Casing Replacement: step 6, image 1 of 3 Philips Norelco Shaver 2100 Casing Replacement: step 6, image 2 of 3 Philips Norelco Shaver 2100 Casing Replacement: step 6, image 3 of 3
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
Jose Moya
176 Reputation
1 Guide authored
USF Tampa, Team S1-G4, Thompson Fall 2017 Member of USF Tampa, Team S1-G4, Thompson Fall 2017
USFT-THOMPSON-F17S1G4
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,020
