Philips Respironics System One REMstar Circuit Board Replacement
  1. Philips Respironics System One REMstar Circuit Board Replacement, Circuit Board: step 1, image 1 of 1
    • Turn the device upside down so that the rubber feet are facing you.
    • Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
    • Gently separate the panel so the wires are not damaged.
  2. Philips Respironics System One REMstar Circuit Board Replacement: step 2, image 1 of 1
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Lift out the inner casing.
  3. Philips Respironics System One REMstar Circuit Board Replacement: step 3, image 1 of 1
    • Remove the motor from the bottom portion of the casing and set it aside.
  4. Philips Respironics System One REMstar Circuit Board Replacement: step 4, image 1 of 2 Philips Respironics System One REMstar Circuit Board Replacement: step 4, image 2 of 2
    • Remove the side panel by lifting it up out of the base.
    • Remove the grouped wire and wire connector.
  5. Philips Respironics System One REMstar Circuit Board Replacement: step 5, image 1 of 2 Philips Respironics System One REMstar Circuit Board Replacement: step 5, image 2 of 2
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  6. Philips Respironics System One REMstar Circuit Board Replacement: step 6, image 1 of 2 Philips Respironics System One REMstar Circuit Board Replacement: step 6, image 2 of 2
    • Separate the green, red, and white wire connectors from their connections on the circuit board.
2 Comments
Do you happen to have a part number or link for replacement pcb?
Kyle Pierce - Reply
Ce anume nu funcționează ?
Mircea Crisan - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 993
