Philips Saeco Poemia espresso machine thermostat and o-ring replacement
  1. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Introduction: step 1, image 1 of 1
  2. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Wiring diagram: step 2, image 1 of 1
  3. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Thermostats: step 3, image 1 of 1
    • After disassembling the machine, it's easy to find the thermostats. They are attached to the top of the boiler with clips. There are two thermostats:
    • 95 ° C - brewing temperature (just below the boiling point of water)
    • 127 ° C - steaming temperature (just below the boiling point of water)
    • You can test the thermostats with a multimeter set to the resistance (ohms) setting. These thermostats are "normally-closed" which means at room temperature, the thermostat switch is closed. The meter should show close to 0 ohms when connected to the thermostat terminals.
    • You can remove the thermostats and check to see that they open when their temperature setting is reached. Carefully use a heatgun and an infrared thermometer to heat the thermostat above their set point. If you overheat them, you will melt the plastic case and destroy them. (Not that I did anything like that.... :-) )
  4. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: step 4, image 1 of 1
  5. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Generic Thermostats: step 5, image 1 of 1
  6. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Modify the generic thermostats: step 6, image 1 of 1
    • The connectors on these generic thermostats need 2 modifications to work with the Saeco Poemia:
    • Cut/file the terminal width by about 1mm. I used a small file.
    • Bend the terminals at a right-angle to match the originals.
    • The mounting tabs are different than the original, but they work just fine under the spring clip.
  7. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Heat sink compound: step 7, image 1 of 1
    • Be sure to put some heat sink compound between the thermostat and the top of the boiler to insure accurate temperature sensing. Any low-cost type will be fine.
  8. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Testing: step 8, image 1 of 1
    • After I replaced the thermostats and tested the machine, I checked the temperature of the boiler with a multimeter and temperature probe. I put the temperature probe under the thermostat clip.
  9. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: step 9, image 1 of 1
    • While testing, I noticed water and steam coming out of the boiler around one of the heating element terminals. Uh oh... I took apart the boiler and replaced the silicone o-ring gaskets. The video was very helpful to disassemble and reassemble the boiler. Checked again - no leaks!
  10. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: step 10, image 1 of 1
Use generic thermostats to make this low-cost repair.
4 other people completed this guide.
Wayne Seltzer
1,732 Reputation
10 Guides authored
Global Fixers Member of Global Fixers
Community
45 Members
702 Guides authored
One Comment
this is a great guide, hard to find stuff about this machine.
Sebastian Muller - Reply
Past 24 Hours: 0
Past 7 Days: 27
Past 30 Days: 112
All Time: 7,460
