Philips Satinelle Disassembly
  1. Philips Satinelle Disassembly, Philips Satinelle Disassembly: step 1, image 1 of 2 Philips Satinelle Disassembly, Philips Satinelle Disassembly: step 1, image 2 of 2
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Disassembly: step 2, image 1 of 3 Philips Satinelle Disassembly: step 2, image 2 of 3 Philips Satinelle Disassembly: step 2, image 3 of 3
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Disassembly: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Disassembly: step 4, image 1 of 3 Philips Satinelle Disassembly: step 4, image 2 of 3 Philips Satinelle Disassembly: step 4, image 3 of 3
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Disassembly: step 5, image 1 of 3 Philips Satinelle Disassembly: step 5, image 2 of 3 Philips Satinelle Disassembly: step 5, image 3 of 3
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Disassembly: step 6, image 1 of 3 Philips Satinelle Disassembly: step 6, image 2 of 3 Philips Satinelle Disassembly: step 6, image 3 of 3
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Disassembly: step 7, image 1 of 3 Philips Satinelle Disassembly: step 7, image 2 of 3 Philips Satinelle Disassembly: step 7, image 3 of 3
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
6 other people completed this guide.
Nathan Christian
505 Reputation
3 Guides authored
IUPUI, Team S5-G5, Wilson Fall 2017 Member of IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Members
8 Guides authored
6 Guide Comments
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
Md Wasim Anwar - Reply
Same here .. wanted to open the bottom part which holds a longish gear .. the top gear fits in a very small portion of the bottom long gear so the long gear has worn out in just that area
S Ahooja - Reply
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
frankgerling - Reply
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
Albert Westhoff - Reply
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 80
All Time: 10,127
