Philips Senseo II 7810 HD Water Level Sensor Magnet
  1. Philips Senseo II 7810 HD Water Level Sensor Magnet, Water Level Sensor Magnet: step 1, image 1 of 2 Philips Senseo II 7810 HD Water Level Sensor Magnet, Water Level Sensor Magnet: step 1, image 2 of 2
    • Pull the water tank off the machine.
  2. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 2, image 1 of 2 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 2, image 2 of 2
    • Lift off the small lid on top of the water tank.
    • The magnet in the float bowl can be seen from above.
    • The float is secured by a metal clip.
  3. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 3, image 1 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 3, image 2 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 3, image 3 of 3
    • Use needle nose pliers to pull out the clip.
    • The water tank is very narrow, so it takes effort and patience to get to the clip. The clip may break, then you will have to secure the magnet later, e.g. with a dab of hot glue.
  4. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 4, image 1 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 4, image 2 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 4, image 3 of 3
    • Open the flap on the magnet with a small flat head screwdriver.
    • The completely corroded magnet becomes visible.
    • On some models, the float looks like the third picture, but the repair is the same.
    • Float
    • Metal clip
    • Corroded magnet
  5. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 5, image 1 of 2 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 5, image 2 of 2
    • Remove the magnet with the flat head screwdriver.
    • Thoroughly clean the case of all traces of rust. Pull out the two pieces of foam rubber on the left and right side and clean them.
  6. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 6, image 1 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 6, image 2 of 3 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 6, image 3 of 3
    • Here is the new neodymium magnet. Its diameter must be 6 mm, height 6 - 7 mm
  7. Philips Senseo II 7810 HD Water Level Sensor Magnet: step 7, image 1 of 2 Philips Senseo II 7810 HD Water Level Sensor Magnet: step 7, image 2 of 2
    • Insert the magnet and the two pieces of foam rubber. Close the float bowl.
    • The case is marked "UP". This side naturally points upwards.
    • Insert the magnet with the float.
    • Put the metal clip back on, unfortunately that's pretty tricky. Long tweezers will help.
Follow the steps in reverse order to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,891 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 18
Past 7 Days: 130
Past 30 Days: 582
All Time: 8,177
