Philips Senseo Quadrante capacitor replacement
  1. Philips Senseo Quadrante capacitor replacement, Opening Philips Senseo Quadrante: step 1, image 1 of 2 Philips Senseo Quadrante capacitor replacement, Opening Philips Senseo Quadrante: step 1, image 2 of 2
    • Never forget: Power off and unplug your device before starting repairs!
    • Remove all attachments such as cup rack, pod holder and water tank.
  2. Philips Senseo Quadrante capacitor replacement: step 2, image 1 of 1
    • Turn the device so that the rear of the machine is facing you.
    • Remove the two Torx T15 screws at the bottom on the machine.
  3. Philips Senseo Quadrante capacitor replacement: step 3, image 1 of 1
    • The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
    • There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
    • Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
  4. Philips Senseo Quadrante capacitor replacement: step 4, image 1 of 2 Philips Senseo Quadrante capacitor replacement: step 4, image 2 of 2
    • At this point, the side panel is still snapped into place on the front, right next to the coffee spout. You can use a screwdriver to carefully pry the latch open.
    • On the inside of the side panel there are two pegs on the top edge that fit in the holes. Lift the side panel up and out.
  5. Philips Senseo Quadrante capacitor replacement: step 5, image 1 of 1
    • The heating element can be seen immediately after the side panel is removed.
  6. Philips Senseo Quadrante capacitor replacement: step 6, image 1 of 3 Philips Senseo Quadrante capacitor replacement: step 6, image 2 of 3 Philips Senseo Quadrante capacitor replacement: step 6, image 3 of 3
    • User a screwdriver to release the catch at the top of the electronics cover.
    • Lift out the cover.
    • Both the electronics and the pump will be visible once the cover is removed.
  7. Philips Senseo Quadrante capacitor replacement, Capacitor: step 7, image 1 of 1
    • The capacitor in question here is blue, it can also have other colors.
  8. Philips Senseo Quadrante capacitor replacement: step 8, image 1 of 3 Philips Senseo Quadrante capacitor replacement: step 8, image 2 of 3 Philips Senseo Quadrante capacitor replacement: step 8, image 3 of 3
    • To get to the capacitor, you'll need to disconnect the terminals at the top and release the latch at the very top of the board.
  9. Philips Senseo Quadrante capacitor replacement: step 9, image 1 of 1
    • The cables at the bottom of the board can stay. Turn the board over and desolder the capacitor.
    • If you have never desoldered/soldered before, this guide can help you.
    • Heat the soldered joints and poke the holes free again with a small piece of wood (toothpick).
    • Solder on the new capacitor.
Work through the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
247,852 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
3 Comments
Let op de + en - aansluiting van de condensator!
Henk Kirchner - Reply
Dit type condensator heeft geen polariteit. Heb je de verkeerde condensator geïnstalleerd?
VauWeh -
Ma machine à café senséo quadrante est repartie, elle date de 2009 (15 ans) elle s’arrêtait complètement en cours de marche.
J'ai remplacé le Condensateur X2 470nF/275V acheté chez gotronic : 3.85 € port compris
Merci pour ce tuto de réparation.
Géo - Reply
Past 24 Hours: 13
Past 7 Days: 36
Past 30 Days: 92
All Time: 2,773
