Philips Sonicare DiamondClean Case Replacement
  1. Philips Sonicare DiamondClean Case Replacement, Case Replacement: step 1, image 1 of 2 Philips Sonicare DiamondClean Case Replacement, Case Replacement: step 1, image 2 of 2
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Case Replacement: step 2, image 1 of 2 Philips Sonicare DiamondClean Case Replacement: step 2, image 2 of 2
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Case Replacement: step 3, image 1 of 1
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Case Replacement: step 4, image 1 of 2 Philips Sonicare DiamondClean Case Replacement: step 4, image 2 of 2
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
3 other people completed this guide.
Zachary Bertrand
843 Reputation
3 Guides authored
IUPUI, Team S22-G1, Bayer Fall 2017 Member of IUPUI, Team S22-G1, Bayer Fall 2017
IUPUI-BAYER-F17S22G1
4 Members
9 Guides authored
One Comment
THANKS SO MUCH , this work very well !
Gaëtan Capou - Reply
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 93
All Time: 7,840
