Philips Sonicare DiamondClean Circuit Board Replacement
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: step 1, image 1 of 2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: step 1, image 2 of 2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: step 2, image 1 of 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 1 of 3 Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 2 of 3 Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 3 of 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: step 4, image 1 of 1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: step 5, image 1 of 1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: step 6, image 1 of 1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
0 Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 60
All Time: 2,819
