Philips Sonicare DiamondClean Metal Brush Connector Replacement
  1. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: step 1, image 1 of 2 Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: step 1, image 2 of 2
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 2, image 1 of 2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 2, image 2 of 2
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 3, image 1 of 1
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 4, image 1 of 2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 4, image 2 of 2
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Metal Brush Connector Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the screw at the base of the metal head.
  6. Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
  7. Philips Sonicare DiamondClean Metal Brush Connector Replacement: step 7, image 1 of 1
    • Gently pull the metal head from the innards.
9 other people completed this guide.
Zachary Bertrand
843 Reputation
3 Guides authored
IUPUI, Team S22-G1, Bayer Fall 2017 Member of IUPUI, Team S22-G1, Bayer Fall 2017
IUPUI-BAYER-F17S22G1
4 Members
9 Guides authored
7 Comments
Great guide - but where is a good source for replacement parts?
Christian Zischek - Reply
Ordered replacement part, came within 3 days at ebay. Didn’t have to replace the soft rubber inlet parts, only the connector.
Piece of cake, exchange of battery seems more labourous, but the brush still works for two weeks, so we postpone this job.
Emilio - Reply
Gut beschrieben, aber wo bekomme ich eine neue Antriebsachse?
Beste Grüße - pechi606
Walter P - Reply
Z.B. direkt aus China : ebay
VauWeh -
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
tim belina - Reply
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 354
All Time: 17,518
