Philips Sonicare DiamondClean Spring Replacement
  1. Philips Sonicare DiamondClean Spring Replacement, Spring: step 1, image 1 of 1
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Spring Replacement: step 2, image 1 of 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Spring Replacement: step 3, image 1 of 3 Philips Sonicare DiamondClean Spring Replacement: step 3, image 2 of 3 Philips Sonicare DiamondClean Spring Replacement: step 3, image 3 of 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Spring Replacement: step 4, image 1 of 1
    • Remove the rubbers covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Spring Replacement: step 5, image 1 of 2 Philips Sonicare DiamondClean Spring Replacement: step 5, image 2 of 2
    • Separate the upper and lower components by sliding the circuit board section and motor section away from each other.
    • Remove the spring.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 96
All Time: 5,606
