Philips TAS7505 Outer Shell Disassembly
  1. Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: step 1, image 1 of 2 Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: step 1, image 2 of 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Outer Shell Disassembly: step 2, image 1 of 3 Philips TAS7505 Outer Shell Disassembly: step 2, image 2 of 3 Philips TAS7505 Outer Shell Disassembly: step 2, image 3 of 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Outer Shell Disassembly: step 3, image 1 of 3 Philips TAS7505 Outer Shell Disassembly: step 3, image 2 of 3 Philips TAS7505 Outer Shell Disassembly: step 3, image 3 of 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Outer Shell Disassembly: step 4, image 1 of 3 Philips TAS7505 Outer Shell Disassembly: step 4, image 2 of 3 Philips TAS7505 Outer Shell Disassembly: step 4, image 3 of 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Outer Shell Disassembly: step 5, image 1 of 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
Joseph Hernandez
174 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 1,027
