Phone Buttons Replacement
  1. Phone Buttons Replacement, Battery: step 1, image 1 of 2 Phone Buttons Replacement, Battery: step 1, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Phone Buttons Replacement: step 2, image 1 of 3 Phone Buttons Replacement: step 2, image 2 of 3 Phone Buttons Replacement: step 2, image 3 of 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Phone Buttons Replacement: step 3, image 1 of 3 Phone Buttons Replacement: step 3, image 2 of 3 Phone Buttons Replacement: step 3, image 3 of 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Phone Buttons Replacement, Buttons: step 4, image 1 of 2 Phone Buttons Replacement, Buttons: step 4, image 2 of 2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Phone Buttons Replacement: step 5, image 1 of 3 Phone Buttons Replacement: step 5, image 2 of 3 Phone Buttons Replacement: step 5, image 3 of 3
    • Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery back being conscientious of wires.
  6. Phone Buttons Replacement: step 6, image 1 of 2 Phone Buttons Replacement: step 6, image 2 of 2
    • Carefully remove the button board to gain access to the buttons.
  7. Phone Buttons Replacement: step 7, image 1 of 2 Phone Buttons Replacement: step 7, image 2 of 2
    • Carefully remove each button from the baby phone.
    • When handling buttons be sure not to misplace the button contacts.
tellocordova
342 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2015 Member of USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 932
