Photive Artisan Portable Bluetooth Speaker Replacement
  1. Photive Artisan Portable Bluetooth Speaker Replacement, Front Panel: step 1, image 1 of 1
    • Before continuing, be sure your device is powered off.
    • Remove two 9mm Phillips #0 head screws from the bottom side of the speaker.
  2. Photive Artisan Portable Bluetooth Speaker Replacement: step 2, image 1 of 1
    • Peel back the rubber feet from either side of the base.
  3. Photive Artisan Portable Bluetooth Speaker Replacement: step 3, image 1 of 1
    • Remove four 9mm Phillips #0 head screws from the bottom of the speaker.
  4. Photive Artisan Portable Bluetooth Speaker Replacement: step 4, image 1 of 1
    • Separate the base of the speaker from the upper housing.
  5. Photive Artisan Portable Bluetooth Speaker Replacement: step 5, image 1 of 1
    • Remove four 9mm Phillips #0 head screws from the inside of the speaker case.
  6. Photive Artisan Portable Bluetooth Speaker Replacement: step 6, image 1 of 3 Photive Artisan Portable Bluetooth Speaker Replacement: step 6, image 2 of 3 Photive Artisan Portable Bluetooth Speaker Replacement: step 6, image 3 of 3
    • Remove all cable connectors from the speaker motherboard.
  7. Photive Artisan Portable Bluetooth Speaker Replacement, Speaker: step 7, image 1 of 1
    • Remove two 7mm Phillips #0 head screws from the front panel.
  8. Photive Artisan Portable Bluetooth Speaker Replacement: step 8, image 1 of 1
    • Lift the speaker from its housing.
David Lennon
10,036 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
45 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 611
