Photive Hydra USB Connector Replacement
  1. Photive Hydra USB Connector Replacement, Face Plate and Back Plate: step 1, image 1 of 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra USB Connector Replacement: step 2, image 1 of 2 Photive Hydra USB Connector Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra USB Connector Replacement: step 3, image 1 of 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra USB Connector Replacement: step 4, image 1 of 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra USB Connector Replacement: step 5, image 1 of 2 Photive Hydra USB Connector Replacement: step 5, image 2 of 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra USB Connector Replacement, Battery (Prerequisite): step 6, image 1 of 2 Photive Hydra USB Connector Replacement, Battery (Prerequisite): step 6, image 2 of 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra USB Connector Replacement: step 7, image 1 of 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra USB Connector Replacement, USB Connector: step 8, image 1 of 2 Photive Hydra USB Connector Replacement, USB Connector: step 8, image 2 of 2
    • Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
  9. Photive Hydra USB Connector Replacement: step 9, image 1 of 2 Photive Hydra USB Connector Replacement: step 9, image 2 of 2
    • Pull the motherboard up and out to remove.
  10. Photive Hydra USB Connector Replacement: step 10, image 1 of 1
Jose Muzaurieta
120 Reputation
1 Guide authored
USF Tampa, Team 11-3, Cheng Spring 2016 Member of USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Members
6 Guides authored
3 Comments
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Abraham Hernandez - Reply
Where can I purchase the usb
Sonia Lance - Reply
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
Sonia Lance - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 772
