Photive Rain Speaker Replacement
  1. Photive Rain Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Speaker Replacement: step 2, image 1 of 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Speaker Replacement, Speaker: step 3, image 1 of 1
    • Carefully remove the front panel from the device.
  4. Photive Rain Speaker Replacement: step 4, image 1 of 1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  5. Photive Rain Speaker Replacement: step 5, image 1 of 2 Photive Rain Speaker Replacement: step 5, image 2 of 2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
2 other people completed this guide.
abcdef ghijk
723 Reputation
4 Guides authored
IUPUI, Team 1-4, Harley Spring 2016 Member of IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 307
