Picture Frame Matting Replacement
  1. Picture Frame Matting Replacement, Picture Frame Matting: step 1, image 1 of 1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: step 2, image 1 of 1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: step 3, image 1 of 2 Picture Frame Matting Replacement: step 3, image 2 of 2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: step 4, image 1 of 1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: step 5, image 1 of 1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: step 6, image 1 of 2 Picture Frame Matting Replacement: step 6, image 2 of 2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: step 7, image 1 of 1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: step 8, image 1 of 2 Picture Frame Matting Replacement: step 8, image 2 of 2
    • Rotate the backing clips under the frame to secure it.
Finish Line
Leah
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 33
All Time: 474
