Pillow Stuffing Replacement
  1. Pillow Stuffing Replacement, Stuffing: step 1, image 1 of 1
    • Measure the length and width of the pillow to determine how much stuffing is needed.
    • A standard sleeping pillow is 20"x26", and will require 2 lbs of polyester fiber fill.
  2. Pillow Stuffing Replacement: step 2, image 1 of 1
    • With the seam ripper, create a 4-6 inch opening in the pillow about 2 inches from the corner.
    • To use the seam ripper: cut one stitch at a time using the sharp end. The red tip should remain upwards.
  3. Pillow Stuffing Replacement: step 3, image 1 of 2 Pillow Stuffing Replacement: step 3, image 2 of 2
    • Remove the existing stuffing from the pillow.
  4. Pillow Stuffing Replacement: step 4, image 1 of 3 Pillow Stuffing Replacement: step 4, image 2 of 3 Pillow Stuffing Replacement: step 4, image 3 of 3
    • Place a tennis ball-sized amount of new stuffing firmly into the 3 intact corners of the pillow.
    • This will help open up and stabilize the shell of the pillow to ensure even distribution of the stuffing.
    • Continue adding stuffing to the pillow to desired stiffness.
    • To ensure a smooth and regular shaped pillow, gently pull at the stuffing until it is fluffy before placing it into the pillow.
  5. Pillow Stuffing Replacement: step 5, image 1 of 2 Pillow Stuffing Replacement: step 5, image 2 of 2
    • Use the scissors to cut a length of thread approximately 24 inches long.
    • A dark thread is used here to maximize visibility. Typically, the thread would be matched with the color of the fabric.
    • Thread the needle and slide it to the center of the length of thread.
    • Triple knot the two loose ends together.
  6. Pillow Stuffing Replacement: step 6, image 1 of 3 Pillow Stuffing Replacement: step 6, image 2 of 3 Pillow Stuffing Replacement: step 6, image 3 of 3
    • Start a ladder stitch from the inside of the pillow by pulling the thread through the folded seam, right behind the opening that you created.
    • Make a small stitch through side of the opening.
    • Make an identical stitch directly across from your first stitch, on the opposite side of the opening. Pull the thread taut to begin the new seam.
    • Repeat, alternating from one side to the other until you have reached the end of the opening.
    • Be sure to keep each new stitch on the folds of the original seam.
  7. Pillow Stuffing Replacement: step 7, image 1 of 2 Pillow Stuffing Replacement: step 7, image 2 of 2
    • To compete the ladder stitch and close the pillow, pierce the needle through both sides of the seam and slowly pull the thread through until a loop is created.
    • Feed the needle through the loop and pull the thread tight.
    • Repeat this once more to ensure that the pillow is closed tightly, and cut off any excess thread with the scissors.
Finish Line
1 Guide Comment
Thanks for sharing. Informative post. Keep up the good work.
Hamptons Cushions
mitu seo - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 63
All Time: 3,725
