Pine64 PinePhone Charging Port Replacement
  1. Pine64 PinePhone Charging Port Replacement, Back Cover: step 1, image 1 of 2 Pine64 PinePhone Charging Port Replacement, Back Cover: step 1, image 2 of 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Charging Port Replacement: step 2, image 1 of 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Charging Port Replacement, Charging Port: step 3, image 1 of 3 Pine64 PinePhone Charging Port Replacement, Charging Port: step 3, image 2 of 3 Pine64 PinePhone Charging Port Replacement, Charging Port: step 3, image 3 of 3
    • Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
    • Remove the battery.
  4. Pine64 PinePhone Charging Port Replacement: step 4, image 1 of 1
    • Remove the midframe from the phone.
  5. Pine64 PinePhone Charging Port Replacement: step 5, image 1 of 1
    • Carefully lift up the vibrator, connected to the board by two wires.
  6. Pine64 PinePhone Charging Port Replacement: step 6, image 1 of 1
    • Applying even pressure, lift up the board.
    • An adhesive is all that is keeping it to the frame of the phone, so there should be minimum resistance.
    • With a new adhesive strip, connect the replacement board to the frame. Make sure to secure the vibrator in the same place as the original.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 1,051
